  • 4516 Views
  • 2 Likes
Rellis
What does the third icon shown for each camera on the devices page mean? There are 3 icons; one for battery strength., one for wifi strength, and a third which I have no clue as to its meaning. The icon has three horizontally stacked lines. The top line is longest, bottom the shortest. Next to the lines is a black circle. I looked at the latest Arlo manual online, no help.
Terk
The third icon on mine is a speaker which means triggered by audio the icon you are describing is the 4th icon on my cameras and means triggered by motion.  When they are grey it means the camarea is not armed when they are black it is armed and I think they light up yellow when recording due to that trigger.
Rellis
Very good. Thank you.
brh
@Rellis
Depending on whether you are looking at the camera in the app or in the web client. You might be looking at the motion detected icon. It should turn amber when motion is detected. Try it and see if that is it.
Brian
