I have the Arlo base station vmb3000 what cameras can I attach to this base station ? I am wanting to add pro or pro 2 camera or cameras or do I need to buy another base station.
You can run the Pro/Pro2 cameras on the older 3000 base....
But if purchase as a kit, the 4000 base is very inexpensive and it gives you a few more options over the older.
It gives you the siren and the USB backup recording to a speed stick. ( with a bit faster processor and more mem )
Also, two bases ( no limit on bases on any account level ) you can truly expand your coverage and run multi schedules... I split my cameras from front to rear yard and the two bases/schedules make it much easier to do this.
Mind that you do need to arm each base separate tho.
Thanks just seen a base on Amazon with 20%off will take in your advise
