1. After contacting Arlo support they find out the base station was still present in my dad account.
2. Had to contact dad, I was able to guide him and he was able to remove the base station and the cameras from is Arlo account
3. Tried to add it again to my account, with no success, performed all the steps proposed by Arlo support (power off, reset, factory reset, unpluged, repluged) but no success (all leds acting normaly and showing the station online and connected)
4. Tried to add it back to my dad account... no success neither!!!
5. Last Arlo support email was only repeating the steps to perform a factory reset... Grrrr
Attempts were made from iOS app and via web portal on a mac. My router see the base station and I also see it's private wifi network... so seems to be connected, up and running. Disabled firewalls, vpn, anything that I know that could block networking... I'm out of idea now...
Am I stuck with a bricked base station? Any idea what else I can try? Look like Arlo support is useless and they closed my case...
At first glance if the base is still showing normal led lights post the factory reset then the base was not successfully factory reset.
Can you confirm that the base LEDs started flashing Amber post the factory reset?
Sometimes you need to hold the factory reset button until the LEDs begin to flash.
Some base station fail to reset because the button gets film residue built up preventing proper contact.
Working the button several times can improve the contact action.
Edit: FYI
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-Base-Station
To be clear, a reset ALWAYS requires that you hold the button until the LEDs flash amber. Any less time means the reset didn't happen.
That said, I've had a similar experience where the base seemed to be working but I couldn't add it. I tried a different base and was immediately able to add it.
Hi DannyBearAgain,
I did make sure all leds were flashing amber. After the reboot cycle is complete I get a steady amber on power led, a green led on internet and an amber led on camera and it stay like that. Trying to add the base station after that doesn't work.
Hi jgerdat,
Leds were all flashing amber.
Would be fun to try to add another base station but I don't have another one...
Sorry I should have said that I get a steady GREEN on power led, a steady green led on internet and an amber led on camera
The steady amber led for the camera usually indicates that the base station is ready to be claimed by an account.
If you have a pc you can use the web browser to login to your account via my.arlo.com and try adding the base station again.
Both the web login and the mobile app requires to be connected to the local network for the adding process to work.
Usually the mobile needs connection to the local wifi and the pc needs Ethernet from the local network router.
All devices are connected to the same network, I confirmed that from my router. Tried to add from an iPhone via the app, an iPad via the app and Safari, a MacBook via Safari and a PC via Edge. None of it worked...
I see the network led flashing when I try to add but the process end up with the "No device was found" message.
I can ping the base station from the ipad, the mas and the pc with normal results...
Any other ideas?
Were the PCs connected using wifi or ethernet? If you can connected them with ethernet, then try that. Maybe do another paper-clip reset of the base, before that attempt.
If you are still struggling to add the base station, I would suggest returning the base to the original network at the original location and seeing if your father can add it back to his account successfully. If so then it validates the base as being viable and should be able to be successfully removed from your father’s account while it is still attached to the original network.
Just be aware that arlo doesn’t publish the way that the account locks/unlocks the equipment so trial and error is your only road.
Good idea, it worth a try... I'll go visit my dad next weekend, I'll bring back the whole set and try it! I'll keep you informed here.
Hi @StephenB
All performed from wired pc. Factory reset performed at least 5 times...
Still no success...
i have the same problem, buy it from a guy and after he deleted i still can't add it to my account
adding on my android phone scans and find it but after give a name just don't goes further and on my windows 11 pc logs out on firefox/chrome and edge.
The cameras may still be linked to his Arlo account. After he deleted them did you do a full reset of each of the cameras?
reseted for couple of times and same problem, on firefox just logs out after giving a name to the station
and the seller told he deleted everything from his account
Good luck @evox … the issue is still not solved for me… I putted everything aside until I have more time to spend on that. Meanwhile I purchased a camera from a competitor that worked out of the box.
i will send it back and will search for another vendor and not arlo, any advice?
