Base station will not work
Your topic header is correct. Contact support using the link at the bottom here to invoke your warranty as specified in the docs.
Have confirmed that is is dead after taking troubleshooting measures?
I can't see that you have thrown your problems into this place before.
The warranty people will probably want to check that you have tried to fiz the problem before they replace the kit.
Just another user
