Want to record when home, but alert when out
  • 1 Reply
  • 1537 Views
Moby58
Hi All,
When home, I would like to record various motions from some Cameras, but not get notifications.
When out, I would like to record various motions from some Cameras, and get notifications.
Is this possible? And how?
Reasoning is, I don't want to be notified every time I go to the shed, but if I suspect someone has jumped the fence while I am inside, I want to be able to check recordings.
That is, record all motion, but only alert when away.
I could do this on my ring cams, so hoping can do with my Arlos.
VMB4540r3 base, and pro 2 & pro 3 cams
DannyBearAgain
Using the library app I can use geofencing to automatically switch to armed mode when away and switch to schedule when at home.
the schedule uses three  custom modes setup to monitor and or alert depending on the time so it can record monitor daytime but will alert me as well  during the evening or set off the siren after midnight.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
DannyBearAgain
