Hi All,
When home, I would like to record various motions from some Cameras, but not get notifications.
When out, I would like to record various motions from some Cameras, and get notifications.
Is this possible? And how?
Reasoning is, I don't want to be notified every time I go to the shed, but if I suspect someone has jumped the fence while I am inside, I want to be able to check recordings.
That is, record all motion, but only alert when away.
I could do this on my ring cams, so hoping can do with my Arlos.
VMB4540r3 base, and pro 2 & pro 3 cams
Using the library app I can use geofencing to automatically switch to armed mode when away and switch to schedule when at home.
the schedule uses three custom modes setup to monitor and or alert depending on the time so it can record monitor daytime but will alert me as well during the evening or set off the siren after midnight.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
