WMA4600 wet inside
  • 0 Antworten
  • 300 Aufrufe
  • 1 in Unterhaltung
Seneconian
Dear Arlo Community,
I have a WMA4600 Solar Pannel and it worked perfectly.
Until recently when I discovered that it got wet inside, i.e. the solar modules are covered with water.
How do I get it out and what is the function of the little hole right next to the plug-in for the charger?
0 ANTWORTEN 0
