WIFI Security
When I turn on my DSL router WIFI password security the camera cannot base unit can not communicate to the router, is there a way to set the base unit up with the WIFI password to have the security on? Look forward to your reply
The base station can only communicate with the router via Ethernet. While you can see the base's SSID, you can't use it for anything. Only the cameras will connect to it.
If you must use WiFi to connect the base to the router (I.e. no Ethernet ports on the router) you can use a WiFi extender that has an Ethernet port.
