hi. Using Arlo H11 cameras. Have tried reinstalling app, rebooting base station. Confirmed on latest firmware. Issue happens with BOTH cameras.
feed from device ‘video settings’ does not work:
live feed from app Home Screen works:
Do you also see this on a PC (my.arlo.com)?
Yes. Same thing.
@Gothacka wrote:
Yes. Same thing.
Does it change if you move one camera closer to the base?
Nope, the distance doesn’t matter
This is still a problem
It's not clear what cameras/base you're using. Can you clear that up? Unfortunately, H11 is simply the hardware revision which could be true on various camera models. The base has a sticker on the bottom with VMBxxxx and the cameras can mostly be determined by looking in the battery cavity for a VMCxxxx on the sticker. The oldest cameras can be figured out by telling us the batteries in use (4 CR123 or a rechargeable battery).
