Video lenght
I have set video lenght 90 second and there is in library now few 2 sec and 5 sec and one 50 second. Most of videos are correct 90 second. Any idea why those short clips?
Try a complete power cycle of the base using the power switch as well as open and close the battery door on the camera (try the base reset first if the camera is a pain). That may do the trick.
Okay,ill try that. Thx fast responce:)
I've tried the recommended fixes and they do not work. Videos continue to record double the amount it's set at. I have many 30 second videos that are actually 3 minutes, 1 1/2 minutes and even 9 minutes in length.
The next thing I'd try would be to create a new mode and rules, especially if the one you're using was one created before the beginning of the year. It may just be a mode that is screwy (technical term).
