Video gets pixelacting and stuttering. Disepointed!! Is it realy this bad???
  • 4 Replies
  • 3916 Views
  • 3 Likes
Hokallabird
Hello!
I have the webcam outside with full signal.. But when im recording to se the video its realy bad.
Time to say good bye to this system och is it anything i can do??
If u mean the Arlo Q , it was meant to be an inside cam.... You could lower the video settings if you have a limited bandwidth.  Haven't seen this problem with the Q
if you mean reg Arlo cam ( this is the q section ) then pixelation happens for a couple of reasons...
low bandwidth, interference, and sometimes server issues (imo).
You could try and move the cam closer too.
Hokallabird
The cam is the standard arlo 720p cam. 50mbit down and up. No problems here in the network.
I hope the Netgerar will come with an update becouse this is serious not good for that money.
The advertising of the product talkes likes it super image 720p.. Not near that. The detail is realy pixeling and no focus.
I reed about many here have the same input.
Will netgear come with some other cam?? With better focus and detail?
Thanks!
Contenj
I have the exact same problem to the point where I think I'm going to return the cameras..was too much bad video captured...pixelated playback..
Contenj,
This could be an interference issue. Do you have more than one camera? Are they both behaving this way? Is the issue intermittent or does it always occur? Check to make sure your camera is getting the best WiFi signal strength.
