VMS3430-100NAS, base station setup, wifi out of range on some cams
i just bought and installed the 4 Arlo cam kit and 1 add on, so I have total 5 cam. I have an issue with 2 out of the 5 cam. My 2 is almost out of range due to wall obstruction and distance. I cannot move the base station in the middle of the house due to space. Can I add additional base station and wifi range extender under same account? What do you recommend? I only want to stick with the 5 cam without having to upgrade subscription.
Without upgrading your subscription, you have few options:
1) Use a long Ethernet cable or aWiFi extender with an Ethernet port so you can reposition the base.
2) Try rotating the base to see if reception improves.
3) Buy a second system and use a second email account.
