We purchased this unit 4 weeks ago
hooked it up and set it up It worked great
Went to use it yesterday and it said it was offline
unplugged it and all three lights came on steady green like it should
It still would not connect to phone or ipad
cleared and rebooted the app with no luck
When we select add base station it cannot find it
the base station is connected to our wifi it is there on thephones
Abie,
If you navigate to Settings and Subscription, does it show that you have a base station currently connected to your account? Be sure that the internet LED is solid green and attempt to connect from a different device (pc, laptop) to further isolate the issue. Please let us know!
What app version/phone/OS? The Android app v2.1.1 is having display issues (cameras offline in the Cameras tab) but the cameras are actually working. If this is the same create a trouble ticket to raise awareness.
