  • 4 Replies
  • 1241 Views
CK123
These cameras just started going offline. Have always worked where they are ..
No changes to positioning.
Any new or moved wireless devices that also use the 2.4GHz band? Check with neighbors, too, if they're close.
Are they always off line?  Or do they sometimes connect?
If this is persistent for all the cameras, then it could be a failing hub.  You could try power-cycling it.
Edinburgh_lad1
I have the same problem. Working ok, connected to the original base station, then going offline. I don't think it's hardware failing as hardware doesn't fail that quickly, and seeing that others have the same problem.
Power cycling solves the problem but until they go offline again.
I'm going to investigate whether it's my internet connection - as I'm using a mobile one - before I'll ask support for help. I should be able to check after the Easter weekend.
It started after that outage.
Edinburgh_lad1
I've checked the now and it's online again.
