VMC 3030 wireless scheduling
I have the manual for VMC 3030 however, I can't seem to be able to create a schedule. Has anyone figured out how to do this, for only one camera or several?
Yes I know the camera is old and no longer supported; however, they work fine. I'd just like to create a schedule.
Thanks.
The details depend on whether you have the older user interface or the newer one.
One shows "Library" in the app (and my.arlo.com), the other shows "Feed" and "Dashboard" instead.
Which do you have?
