VMC 3030, i have several vmc 3030 cameras, some are 110 fov. and some are 130 field of view,
  • 1 Reply
  • 3357 Views
paddyy
hi
i recently  purchased several netgear  vmc 3030 cameras, some were printed on box as 110 degrees field of view but  some others were 130 degrees field of view. set the up and sure enough there was a difference in  picture.
unsure now if one type may be old stock.
can any member shed any light on this please, much appreciated....thanks
I just check some of the older pdf maunals re product and it lists as 130degrees.. back in 2014.
Tho I do remember 110 being a known FOV  in the Arlos.... Not sure if the original Arlos ever went 130d  , but stay at 110 d
What are the features and specifications of the Arlo Wire-Free system?
The Arlo Wire-Free camera system has the following features:
  • 100% wire-free
  • HD video
  • Outdoor ready
  • Night vision
  • Motion alerts
  • Free app
  • Cloud storage
Camera Specifications:
Video resolution
Configurable up to 1280 x 720
Video format
H.264
Imaging
Full color
CMOS
Auto-adaptive white/black balance and exposure
Motion detection
Adjustable sensitivity
Automatic email alerts and push notifications
Digital pan and zoom
Yes
Night vision
850 nm LEDs: illuminates up to 25 feet
IR cut-off filter
Battery
Four (4) Lithium CR123 Photo
Battery level indication
Yes
Battery life
4 to 6 months
Field of view
110°
Focus range
Fixed focus (2 ft to infinity)
Operating temperature
14° to 122° F (-10° C to 50° C)
Dimension
2.8 x 1.6 x 2.5 in (71.2 x 40.64 x 63.5 mm)
Weight
0.25 lbs (0.11 Kg)
Base Station Specifications:
Interface port
Fast Ethernet
Indicator LEDs
Power, Internet, Camera, Smart Home, USB
IP configuration
DHCP
Antenna
Internal
Wireless range
300+ feet line of sight
Wireless
2.4 GHz
802.11n
Processor and memory
500 Mhz MIPS 74 K processor
128 MB Flash, 128 MB RAM
Certifications
FCC, IC, CE, UL
32° to 122° F (0° to 50° C)
Dimensions
8.5 x 2.25 x 6.5 in (215.9 x 57.15 x 165.1 mm)
Weight
0.25 lbs (0.11 Kg)
What are the features and specifications of the Arlo Pro Wire-Free camera system?
The Arlo Pro Wire-Free camera system has the following features:
  • 100% wire-free
  • Rechargeable batteries
  • AC power option
  • 2-way audio
  • HD video
  • Wide-angle lens
  • Weatherproof
  • Night vision
  • Motion and audio detection alerts
  • Siren
  • Geofencing
  • Scheduling
  • Free app
  • Cloud storage
  • Local backup storage
Video resolution
Video format
H.264
Imaging
Full color
CMOS
Motion detection
Sound detection
Audio
Speaker
Microphone
Digital pan
8x digital zoom
Night vision
Battery
2440mAh Li-ion rechargeable
Yes
Battery life
Varies based on settings, usage, and temperature
Power adapter
120V AC
Power adapter cable
USB to Micro USB
Field of view
130°
Focus range
-4° to 113° F (-20° C to 45° C)
Water resistance rating
Water-resistant IP65
Dimensions
3.1 x 1.9 x 2.8 in. (79.3 x 48.6 x 70.5 mm)
Weight
4.8oz (136 g), not including the 3.6 oz (102 g) battery
Interface port
Fast Ethernet
USB ports
2 USB 2.0
Indicator LEDs
IP configuration
DHCP
Antenna
Internal
Wireless range
Up to 300 feet line of sight
Wireless
2.4 GHz
802.11n
900 MHz ARM processor
Certifications
FCC, IC, CE, UL
Dimensions
2.3 x 6.9 x 5.0 in. (58.6 x 174.5 x 126.5 mm)
Weight
11.1 oz (316 g)
