VMC 3030, i have several vmc 3030 cameras, some are 110 fov. and some are 130 field of view,
hi
i recently purchased several netgear vmc 3030 cameras, some were printed on box as 110 degrees field of view but some others were 130 degrees field of view. set the up and sure enough there was a difference in picture.
unsure now if one type may be old stock.
can any member shed any light on this please, much appreciated....thanks
I just check some of the older pdf maunals re product and it lists as 130degrees.. back in 2014.
Tho I do remember 110 being a known FOV in the Arlos.... Not sure if the original Arlos ever went 130d , but stay at 110 d
What are the features and specifications of the Arlo Wire-Free system?
The Arlo Wire-Free camera system has the following features:
- 100% wire-free
- HD video
- Outdoor ready
- Night vision
- Motion alerts
- Free app
- Cloud storage
Camera Specifications:
Video resolution |
Configurable up to 1280 x 720 |
Video format |
H.264 |
Imaging |
Full color |
Motion detection |
Adjustable sensitivity |
Digital pan and zoom |
Yes |
Night vision |
850 nm LEDs: illuminates up to 25 feet IR cut-off filter |
Battery |
Four (4) Lithium CR123 Photo |
Battery level indication |
Yes |
Battery life |
4 to 6 months |
Field of view |
110° |
Focus range |
Fixed focus (2 ft to infinity) |
Operating temperature |
14° to 122° F (-10° C to 50° C) |
Dimension |
2.8 x 1.6 x 2.5 in (71.2 x 40.64 x 63.5 mm) |
Weight |
0.25 lbs (0.11 Kg) |
Base Station Specifications:
Interface port |
Fast Ethernet |
Indicator LEDs |
Power, Internet, Camera, Smart Home, USB |
IP configuration |
DHCP |
Antenna |
Internal |
Wireless range |
300+ feet line of sight |
Wireless |
2.4 GHz 802.11n |
Processor and memory |
500 Mhz MIPS 74 K processor 128 MB Flash, 128 MB RAM |
Certifications |
FCC, IC, CE, UL |
32° to 122° F (0° to 50° C) |
Dimensions |
8.5 x 2.25 x 6.5 in (215.9 x 57.15 x 165.1 mm) |
Weight |
What are the features and specifications of the Arlo Pro Wire-Free camera system?
The Arlo Pro Wire-Free camera system has the following features:
- 100% wire-free
- Rechargeable batteries
- AC power option
- 2-way audio
- HD video
- Wide-angle lens
- Weatherproof
- Night vision
- Motion and audio detection alerts
- Siren
- Geofencing
- Scheduling
- Free app
- Cloud storage
- Local backup storage
Video resolution |
Video format |
H.264 |
Imaging |
Full color |
Motion detection |
Sound detection |
Adjustable sensitivity Automatic email alerts and push notifications |
Audio |
Speaker Microphone |
Digital pan |
Night vision |
850 nm LEDs: illuminates up to 25 feet |
Battery |
2440mAh Li-ion rechargeable |
Yes |
Battery life |
Varies based on settings, usage, and temperature |
Power adapter |
120V AC |
Power adapter cable |
USB to Micro USB |
Field of view |
130° |
Focus range |
-4° to 113° F (-20° C to 45° C) |
Water resistance rating |
Water-resistant IP65 |
Dimensions |
3.1 x 1.9 x 2.8 in. (79.3 x 48.6 x 70.5 mm) |
Weight |
4.8oz (136 g), not including the 3.6 oz (102 g) battery |
Interface port |
Fast Ethernet |
USB ports |
2 USB 2.0 |
Indicator LEDs |
Power, Internet, Camera |
IP configuration |
DHCP |
Antenna |
Internal |
Wireless range |
Up to 300 feet line of sight |
Wireless |
2.4 GHz 802.11n |
900 MHz ARM processor 128 MB Flash, 128 MB RAM |
Certifications |
FCC, IC, CE, UL |
Dimensions |
2.3 x 6.9 x 5.0 in. (58.6 x 174.5 x 126.5 mm) |
Weight |
11.1 oz (316 g) |
