VMB5000 on board into app error
  • 1 Reply
  • 1678 Views
mstanton
I have a problem on boarding a ARLO smarthub VMB 5000 onto the app i get the following error.
The operation could not be completed
(arloNetworking.ServerResponseError 1.)
Any Ideas?
I haven't heard of that one. Try resetting the hub by holding the reset button until the LED starts flashing amber. Let it reboot to solid blue (~2 minutes) and try adding it to your account again. If you happen to be using a VPN, disable that during the installation.
