VMB500 will no longer connect
It was all working last week.
I can no longer connect my smart hub with add device.
Did a the hard reset on hub and home network, unplugged everything.
I am connected to a 2.4g network. plugged everything back in, in sequence.
hub flash's Amber then settle on the Blue light. but will not add device.
Message 1 of 2
426
Since you manually reset the hub, you must also remove it from your account before you can add it back. Here is an FAQ that covers the complete process:
https://kb.arlo.com/1057976/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station
Message 2 of 2
404
