VMB4000
  • 1 Reply
  • 1687 Views
Wildhorse1
I have 2 VMB4000 units that I have had for a few years.  None of the cameras work anymore for either unit.  Can I replace just the cameras and which cameras do I need to purchase.  My one unit is located in a cold climate and the original cameras did not work well.  Thanks for the info... I'm a 75 year old guy and get confused with this stuff
You can, but you would need an Arlo secure subscription for the replacement cameras.
What cameras do you have now?  (If the batteries are removable, then take the camera out of the housing and remove the battery.  There is a label inside).
Did the cameras all stop working at the same time?  Or was this gradual.
