VMB3500r4 disconnect from the router no IP
Problem base station VMB3500r4 disconnect from the router
Troubleshooting:
I have a arlo VMB3500r4 hub and after a firmware upgrade i had to factory reset to reconnect to my router. at first work and all cameras connect without a problem but after a few hours looks like the hub looses connection with the router.
I have tried different cables (RJ45) on different ports (same problem)
I have tried connecting to mu router and to my extender (same problem)
I have tried several factory resets
I have tried connecting the hub to the router with no cameras added and after a few hours looses connection to the router (same problem)
I have tried set up via laptop and phone (same problem)
Other comments:
when I look for the device on my router or extender the device is not found only after a factory reset the device connects to the router
current firmware 1.18.0.3_1036_d554faf
hardware VMB3500r4
current lights
solid green (power)
internet off
solid amber (cameras)
any help will be appreciated
Ivan
It rather sounds like the Ethernet port on the base is the issue, either a poor connector or the Ethernet hardware inside the base. You've tried everything I'd suggest. At this point, you can either attempt to fix it yourself (no other repair is possible) by opening the case and check the physical Ethernet port for proper connections inside the port as well as to the circuitboard or just buy a new base or hub.
thanks all looks good. looks like the problem is with the firmware that does not completed installing and fails after a few hours then loses the connection to the router
