  • 2 Replies
  • 1693 Views
EmilianoM
Hello,
I have a VMB3010r2 Arlo Base Station with the 1.10.0.4_20963 firmware version.
The system is proposing me to upgrade to 1.10.0.7_21310 firmware release but the process every time finishes with base_station_errore_4403.
Any change to perform the firmware upgrade successfully?
I already checked release notes here: Release Notes – Arlo Pro Base station, Arlo Wire-Free Base station 21st June 2018.
 My system is described here: Telecamere WiFi da esterno a batteria Netgear Arlo
Usu if you reboot the base ( power button ), the FW will attempt an update...
Is the issue a data speed issue??  Slow data speeds can cause fw update issues.
EmilianoM
Hi Tom,
I was trying to upgrade only through web interface.
Restarting the base station everything now is fine !
Thanks for your support.
