  • 2 Replies
  • 942 Views
hfd50skip
lost power, was able to get three cameras up but the last two will not sync. took batts out and back in still will not syns. sync light works on the station, after pressing the sync on cameras for about 2 sec about 3 feet away, yellow light on cameras flashes. plugged into router both sitting next to each other. any ideas?
The slow amber LED on the camera indicates nearly dead batteries. Put good one in and you may not even need to sync again.
A UPS for your modem, router and base helps fly through most power outages.  The issue is that the cameras keep trying to contact the dead base, wearing down the batteries.  The UPS keeps the base and network up so the cameras an base think nothing has happened.
hfd50skip
Thank you, will try.
