One of my camera works close to the base station , about anywhere in the living room where the base station is . When i take it outside and put it back on the bracket it just wont work . And the mounting bracket is'nt 15 ft from the base station . The other cameras are working fine , one of them being maybe 150 ft . Im figuring camera is defective. I have re-added the camera and tried everthing . Nothing works . if these things have a antenna type sensor to work the wire cams , then i'm looking toward that . Any help from tech appreciated .
Yep , i had a bad camera , It's on it's way for a return swap . Thanks to all the replys
VMB3000 , sorry for typo error
Swap cameras with a good one. If the problem stays with the location, you'll have to troubleshoot the location. You'll need trial and error to figure it out. If the issue remains with the camera you should create a trouble ticket for additional hell and maybe an RMA.
That was the first thing i tried . I brought it to the closest location from the back of home to the front , which is a few feet of the base . I've tried everything i know of , it just loses the signal
That was supposed to be "additional help" - Freudian slip??
Open a trouble ticket - sounds like you have a bum camera.
