Since a few days I have problem with "Direct Storage Access" in the app I cannot get the "switch" to enable direct access to stay enabled, as soon as I switch on, it switch of directly. anyone experience this, I can watch live videos and if I connect the external disc to PC I can view the videos. The USB symbol in the app is black but grey in the www.arlo.com and the switch for "record locally is green but faded out and I cannot turn off or on.
Best answers
@aadasme wrote:
Verisure bought Arlo, therefore they are running the show now.
Not really. They purchased only the European operations, and Arlo is an American company. Arlo remains an indepdendent, publicly traded company, and Verisure has no ownership stake.
@ShayneS Any update on this ? sorry but it's really bad that it's taking so long to fix a software issue.
Is there any news, the problem has not been solved in Arlo?
Hi @Roman119
I am waiting on more information from the team. I will update the thread as soon as possible.
Thank you
Good afternoon! is there any news?
I think they never gonna fix the issue? One month whitout an answer
Yes, it looks like they don’t care. I had a meeting with Arlo and provided all inputs, it’s almost 1 month over but no updates.
Anyways, i added all my cameras to Verisure subscription as I can’t wait anymore for Arlo to fix this issue.
yet they achieved their goal((
This is for real a serious case of I dont care for arlo
Record locally toggle switch greyed out and unable to use. No recordings from cameras recorded locally.
please help
VMB4540 base station
2 x Arlo pro floodlight
1 x Arlo camera
I've decided to reset everything and am now paying a high price for it. New firmware uploaded to the SmartHub 5000 (1.24.0.0_1606_5df44bb) and local storage isn't working. Tried three different SD cards. Could someone, with the same firmware, please confirm whether it's my SmartHub or a wider issue - please remove and re-insert the SD card. Thank you.
Clearly, after removing the SD card, there's a new folder created in the root directory, so this appears to be the new firmware that's causing an issue. However, I'll wait for other reports before stating categorically that it's the case.
@JamesC @ShayneS @BrookeN
What's more: the new firmware (either for the hub or the original Netgear Arlo HD, FW: 1.6.297) has introduced an option to record for this particular type of camera until activity stops (this option is *only* available on the web), resulting in the camera recording for 5 min., even when the activity is no longer taking place. As far as I know, this particular camera *can't* record until activity stops, but only for a set period of time.
So, in a way, as a Scots saying goes: it's back tae auld claes an parritch (= business as usual; in this case: fix one thing and break another)
Could someone with the same firmware please confirm that their local storage is working properly please?
@JamesC When will this firmware issue be fixed please? If not anytime soon, please force an update of the previous version to my SmartHub. My subscription runs out at the end of April and I'd like the issue to be fixed by then (22 April to be precise).
Quite frankly, I've not had an incentive to give your company more of my hard earned money, in this case to renew.
(I'm far from being pleased: constant problems with the app/SmartHub/cameras, wasting my time to troubleshoot; new User Experience making things difficult to set up; very poor customer attitude overall which, because of the above, doesn't put the customer at the centre.)
Thank you.
