  • 2333 Views
Evansx5
Over the past 8 weeks my base station has gone offline every 2-3 days. Given I travel a lot, this is hugely frustrating. Each time it happens, I follow all the helpful advice from the community - i.e. add new device/turn off-on/factory reset...you name it. Whilst it works for a few days, it ends up dropping out again. It's costing me a fortune in wasted batteries.
All suggestions will be helpful - be that how to fix the problem or a recommendation for an alternative home security service.
What are the LEDs showing when offline? Have there been any power interruptions?
Evansx5
Many thanks for your response. 2 green lights (left to right) are showing. There have been no power outages - the base station 'drops out' quite randomly every 3-5 days. There is no specific pattern nor discernible cause.
The lack of a green Camera LED means no cameras are connected. This can be due to 2.4GHz interference (likely near the base since all cameras appear to be affected). Try repositioning the base further from the router but also check for other devices that use the 2.4GHz band, WiFi or not.
It may be useful (but a PITA) to remove all devices from Settings, My Devices and start fresh. Maybe something in the configuration is weird, causing the problems. Be sure to note all settings, Modes, rules and schedule before doing this to speed the rebuilding process.
