VM3430-100NAS REPLACEMENT FOR VUEZONE NO ARMED OR UNARMED OPTIONS
Unable to arm or disarm cameras. Only option is for shedule, full motion or no motion. Where is the disarmed option?
osageoffice wrote:Unable to arm or disarm cameras. Only option is for shedule, full motion or no motion. Where is the disarmed option?
Armed is all cameras set for motion record
Disarmed is for all cameras off in sleep mode , no record unless manual turned on and/or live view
SETTINGS>CAMERA> toggle on/off to disable camera completely ( no view at all till turned back on )( esp good if camera shared and in private area )
So, the 'no motion' is the disarmed, motion is armed... When armed and active for motion record the "running man" will be black in the camera view ( upper corner)
