  • 7379 Views
slim4684
My WiFi is too weak when it gets to my shop so I plan to install the AC1200 Netgear Range Extender and add cameras to a SECOND Arlo Base Unit (I have 6 on my first base unit).
I plan to connect the second base unit by ethernet cable to the AC1200 Range Extender...This rig should work-correct?
Should work, yes.
Should work, yes.
slim4684
Thanks! You the only one working? You seem to be my personal Arlo Guru
Ha!  I accept spare change and bills with lots of zeros...  🙂
