Usb
  • 1 Reply
  • 1033 Views
lnorda
I have a VMB4000 base station.
I would like to connect a USB device for backup. I can't format the one I have. Can you tell me which are the appropriate devices I can use?
 What do you have?
I generally recommend a name-brand USB thumb drive in the 128-512 GB range.
I've used Sandisk with success, though other brands (including Kingston, Patriot, PNY, Transcend) should also work.
