Upgrade from Vuezone to Arlo
  • 1 Reply
  • 2742 Views
tac2379
I'm considering upgrading to Arlo with the deal Netgear is offering to existing Vuezone customers.  I have a Vuezone system with two outdoor shells which were difficult to install. I can easily remove the plexi camera shells to replace the batteries but the stems are hard to access.  Do the Arlo cameras have the same diameter threaded post/receiver as the Vuezone outdoor shell system?  If so can I just spin new Arlo cameras onto my existing stems without having to buy new outdoor mounts and install them?
I don't have any VueZone cameras but I believe that both cameras have standard camera mounts - 1/4"-20 threads. If you used a standard camera mount, you'll be fine with an Arlo camera on them. You may not be able to easily change batteries without taking the camera off, though.
