Update on pan&zoom vs. recorded night image quality?
  • 5 Replies
  • 3665 Views
TB75
I hope that case #26746446 can be resolved soon.
This is the only thing holding me back from buying more cameras and recommending them to others.
Netgear, is there any update or plan for this?
Thank you.
5 REPLIES 5
TB75,
This specific case does not appear to be registered by you. Do you have an open support case I can reference on the issue you are describing? If so, let me know and I will review and escalate the case as necessary.
TB75
Hi James,
No, that case was registered by another user.
Please consider this an additional vote to move it forward, or enter another case that is linked or referenced to that one if that is more effective.
The night image in pan&zoom is much better than what is recorded - there is a clear difference in image sensor settings there.
Ideally there needs to be the ability to have separate settings for daytime vs. nightime video recording. Dialing up the brightlness for nightime can wash out the daytime image.
Thank you.
TB75
Hi James,
Any update on this issue? Is it already on the bug fix or feature roadmap?
Thanks.
I will escalate the case and see If I can find out any information the topic.
TB75
Thank you James.
