  • 1435 Views
LA_phx
recently had App update as Version 2.7.4_25567 released March 25, 2019 (have Android/Samsung S8) (firmware 1.125.11.4_29092).
 Add-on camera does not show the recordings after motion detected but do get the notifications.
Restarted the Arlo device, turned off/on the camera itself, any idea why no recordings are present?
Which notifications - push or email? Is there a filter set in the library? The funnel icon at the top should be empty, not filled.
LA_phx
Push Notification
I never had to mess with the filter. I am seeing a solid green funnel. what does that indicate?
It means a filter has been set which will exclude recordings not from the selected cameras. This is frequently caused by clicking on the numbered circle for a camera in the Devices tab.
To clear it, click on the icon and reset/save.
