I have two arlo cameras and an alarm base.
My app shows that I need to update firmware but I'm not able to to launch the firmware update.
Arlo help says to find the firmware update on my.arlo.com under settings but I do not have those options.
All I see is shared devices and ability to rename them.
How do I update my Arlo cameras?
@arlouser75068 wrote:
.... I'm not able to to launch the firmware update.
What are you doing and where does it go wrong?
You don't say which Arlo gubbins you have, but for Ultra Pro ", in the browser interface:
- Settings
- Arlo Pro Hub (or camera)
- Device Info
- Firmware
If there is an update available it should show up there.
Another way in is:
- Devices
- PIck a device
- Click the Settings icon
- Device Info
The strategy is much the same on the app.
Just another user
