I am unable to log into view my cameras anymore, just sends me back to screen that says “log back in”
Occasionally an error message will show at the top but it’s intermittent and says
(0) http status code to ‘(null)’ .
Any ideas! It’s driving me mad
Ok, check that, I now can no longer log in from either my phone or my computer. Should I create a new account and start over? I can't be paying hundreds per month for something that doesn't work at all.
Hi MKelleyToo,
This is a really annoying issue that many Arlo users are putting up. But, there are two options that have allowed me to log in to the iPhone Arlo App. One, which is the most annoying of the two is to power your phone down, then on again. This will give you a one-time access to the App. The second option, which is easier but I'm not sure of the ramifications, is to switch off the VPN in your iPhone Settings. This will give you access to your Arlo cameras for as long as your VPN is in the off mode. The Arlo support team (or lack of support team, I should say) has been unresponsive to this problem. I first reported the difficulty back in early June. The only way I discovered the work arounds is by reading the posts in the user community forum. Good luck, I hope this helps.
cannot log in. shows user name but will not go to cameras.
Have reinstalled app (3x) rebooted router
Able to log in from home computer and wife's phone (same model and IOS) no problem
Created a secondary account with different username and email. Same issue.......
Any help is appreciated.
regards
I’m getting this error message while away, not connected to home WIFI. (0) http status code to ‘(null)’
What is that message from, and what are you doing when you see it?
Just another user
@dvass96 wrote:
I have to shut down my iPhone each time I try to log in on the Arlo app.
Not enough to go on there.
What are you doing when this happens? What prompts and error messages do you see?
Just another user
I log out, attempt login again, same error. Thanks.
@SMS200 wrote:
When I’m away from home, when I try to log in, no log in happens and this error message pops up.
Login to what?
Your my.arlo account in an app?A bookmark somewhere?
Is this a mobile device? Android? iOS?
Something else?
You'll have to provide some useful details before anyone can begin to guess what is going wrong.
What are you doing when you see that message? Take us through the process a step at a time.
Just another user
Not able to log in with iPhone. Able to log in on browser and iPad. Just updated to iOS 13.6 on both devices, and deleted then re-installed Arlo App on phone, but still unable to log in.
I am still on 13.5 IOS but see the update and not have updated it. It works fine on phone. It is possible the update caused it. I may hold off on updating to see if it is the problem and if Arlo updates the app this week.
Thanks.
Just to let you know I just updated to IOS 13.6 and the app works fine so that is not the problem.
As far as I know, I am up to date on software and firmware on the Arlo since it does it automatically but it is 1.096.3.0_1.8.56.0_0.6.5.18.AT.025 . I have 2 phones, an Iphone Xs and an old Iphone SE on another line. I've tried sharing access with the other phone and, after creating another account on that device, the invite sends a link to the site and there's no place to actually accept the invitation to share access. It even didn't recognize my Iphone XS as a trusted device even though it is the device I set it up with and is my primary and has been the whole time. My Iphone software is updated to iOS 13.6 and has been since the problem started weeks ago, app is updated, I've uninstalled and reinstalled many times. I am getting ready to removed the device from my account, take out the battery, reinstall battery, then re-add to account. It worked last time when the damned thing wasn't detecting motion. I'm about fed up with this. Its actually hasn't been working properly more than when it has in the past 3 months. I had some former employees break in yesterday and I didn't even know until I finally got logged in on my laptop. No notifications via email, no alerts, nothing.
Are you running the VPN on your phone? Someone in an earlier thread mentioned it. I turned my VPN off and the app booted up like a charm. Now, the question is, will it do it again in about 20 minutes.
Jessica, those of us on this string have ascertained that the issue seems to stem from VPN. If we turn off VPN, the app works. However, this is not a solution. Can you give us any additional progress with the developer regarding the issue?
Is the problem not solved in the meantime? Same problem with iPad Pro iOS 13.5.1. Re-installed App but still the same problem...
