  • 9 Replies
  • 457 Views
barneyme2s
Since yesterday I am not able to manually turn on camera for a live view.
9 REPLIES 9
Have you done anything to troubleshoot?
barneyme2s
FYI: I am using a computer, not a smart phone app.
I have two systems with five cameras each and not able to go live with any camera. I disconnected then reconnected, no help.
This happened in March and after a few days it started working again without me doing anything. I suspect it has to with something ARLO did, or didn't do.
If it is on my end, I have no idea what to do.
By-the-way, the cameras are recording and detecting motion.
Edinburgh_lad1
I have this problem with my Arlo HD. Intermittent, though. Initially, you can live view, but then you can't. I only use it as an indoor camera to live view. However, I'm keen to find out why this problem occurs. Also, I've removed, reset and re-added the camera and this doesn't help.
I would try power-cycling the hub next.
barneyme2s
Tried that, no help.
Have you also tried removing/reinserting the camera battery?  That reboots the camera.
barneyme2s
No I have not, but I have several cameras and it makes no sense to me to do that to every camera. I may try one later as a test.
So this happens to all your cameras at the same time?
That makes sense.  No need to try them all.
barneyme2s
I'm also talking to someone else and it seems to be a problem with Arlo's TURN servers.
Here is the message received:
Arlo’s TURN servers are not reachable from your device right now.
