In the vehicle recognition listed vehicles when I go in and try and delete the vehicle that’s doesn’t belong it try’s to delete but when it is done thinking the vehicle is still there nothing is deleted.
@Angela706 do you mind sending me a video of the behavior you are seeing? Also your firmware version and are you on iOS or Android.
- 6.36.0 version it iOS and so far couldn’t get the video to work for the email
only could get screenshots of them thinking of deleting the wrong vehicles and then when it’s done they are still there not deleted.
Can we try to uninstall and reinstall the app to see if that makes a difference?
I’ve got screenshots but no video
Did you uninstall and reinstall the app?
Yes I’ve uninstalled and finally got my cameras back in and that doesn’t make a difference
I have reached out to our development team to investigate the behavior you are seeing. I will update the community as soon as possible.
@Angela706 are you still seeing this same behavior?
Yes
Yes even with this latest update the unrecognizing vehicles still didn’t show up.
Can you please double check that you are on the newest firmware.
6.40.0is version newest
Try uninstalling and reinstalling your app one more time please.
Seems to be working for me on 6.40 as well as the web client. However, there were a whole slew of thumbnails that wouldn't/couldn't be loaded or even clicked on. They were just blank gray thumbnails with a horizontal zig-zag pattern (I guess that was to show they were broken).
Sure did that and it was a pain to reload everything and still the same exact issue nothing has changed.
After deleting all unknowns yesterday, I now have 18 to check out. However, there's no way to tell what they are:
Mine does the same exact thing and thank you for adding another pic to show the issues
If you turn vehicle recognition off and then back on does it load?
No it doesn’t and to add to that the notifications are not clearing out when at the feed unless you close the app then go back in then the notifications will go away till.
Alright thank you for letting me know. I will pass this onto our development team.
@Angela706 Are you still seeing this same behavior?
Yes the notifications are still staying on unless you get out of the app and then go back in to the app, they will go away.
