Unable to add 5th Camera to Base unit
  • 1 Reply
  • 1418 Views
Sammie16105
Changed settings to indicate using 5 cameras. Camera blinks rapidly blue like it is syncing with base unit, yet never does. Camera never shows up in list of cameras added. Powered off base unit, still no good, help!!!
Pull battereis and replace...attempt sync again ( remember quick push on base sync button , not hold )
Some time a power button reboot of the base is needed for it to appear ( you tried that ), do again. if you get slow blue then fast blue led on cam
