  • 8 Replies
  • 1132 Views
ziloty
Arlo Web Portal|Smart Home Security there is no buy button in this page. how can I do buy arlo secure subscription?
8 REPLIES 8
Where are you located? Not all regions can get subscriptions.
ziloty
Atlanta, Georgia
Hmmm. SHould be working then. Have you tried clearing the browser cache and/or a different browser?
ziloty
I tried everything. New browser, incognito mode, mobile browser. And also no one responses in support chat. Only bot
The mobile browser needs to be set to use the desktop site to work properly, I suspect. However, that seems to only work on Android. Any chance a VPN is in use?
Can you  use the app instead of the browser?
ziloty
Should I try to use vpn? On which region please suggest
Sorry, I was suggesting disabling any VPN, not trying to use one.
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
