  • 1 Reply
  • 1738 Views
Raybonser
Base station has two USB ports. Will this record activity directly on this system to an installed USB drive so it can be retrieved at a later time
On the Arlo ( original ) base, the usb port were never activated
On the Pro/Pro2 base, the usb ports cna be used as a backup drive ( like a speed stick, up to 2 TB ), but it really is a backup only. Any videos that are triggered by motion go to the library and the usb backup, but the usb drive must be ejected properly and then used in a computer to view the mp4 files
