  • 4 Replies
  • 4208 Views
Berrost
I have one account established and love it, 4 cameras at my house linked to a ATT router. I plan to add another system at my apartment 100 miles apart and it has Time Warner Internet, will I be able to have all the cameras and feeds on one account and will I be able to control them independently or am I better off with two accounts?
i don't use the schedule function they will either be on or off if that matters.
thanks
That's up to you...
to combine two bases (unless levels have changed )in one account required Elite service  for up to 3 bases.
You can run two bases under diff log-in and email accounts if you want but they will be separate
JonEKelly
Each set of camera will be tied to one base.  You control those cameras by that base.  You will need to sign up for Elite so you can have up to 3 bases.
I currently run two base units at two different locations.  One is tied to Verizon wireless and the other is tied into HughesNet.  Both appear under the same login.
Apparently the latest updates have changed this.  It's no longer tied to the number of bases and cameras but just the number of cameras.  However, don't take my word as gospel - check it out since I might have it wrong.
Correct...I ask the same question of Netgear staff... Number of bases is no longer a factor of service level.
Basic level can have multi bases now.
