Hi
I have 15 Arlo cameras in my home. After Arlo Pro arrived I want some of these cameras to.
Question. Can I keep 15 cameras in my "old" system ,and by new Arlo Pro base station and new Arlo Pro cameras and use them as two seperate systems
in my house ?
Yes but you'll need to use a second email address for a new account since you've maxed out your 15 camera subscription (the Elite plan only supports up to 15 cameras). You could use the free 7 day plan for your Pro system or upgrade that account, too, if your need for additional days is important.
I would use the PRO base on a Basic level of 5 cameras for 7 days storage since you CAN put a usb speed stick on it to backup the cloud files for a much longer time ( as long as space ).
Also separate the more critical cameras to the Elite plan and the less important cameras to the Pro base for same reason,
