Two Hubs - 8 cameras - ONE ethernet port available
  • 1 Reply
  • 875 Views
carolbpeter
We have 8 cameras - all necessary (wish I had 2 more) - and two hubs.  But, only one ethernet connection available.  I am using the 2nd one for my work computer.   Is there ANY WAY to get both the hubs on one ethernet connection?  Or is there a hub that will handle all 8 cameras?  Really pointless to have the cameras if they're unable to tell us anything.
Best option is to purchase a small gigabit switch.  You can find 5 port switches for $20 USD or less, and that would result in 5 ethernet ports total (not counting the connection between the switch and the router).
 You can connect all the cameras to one hub, but there is a limit of 5 simultaneous streams at once.  So in some situations you would lose recordings.  So I recommend using both, but adding in the switch.
If practical, put the hubs in different rooms, so you can get a bigger coverage area.  Though that might require some wiring.
