Has anyone had trouble setting a time schedule in the app? When you set it at 4, the app says 3 and also will not allow you to set 11 or 11:59. It only goes to 10:59
possibly due to the time change for daylight savings? Also wanted to make Arlo aware. Thanks!
Not here.
You don't say which app. I did find that the Android app had problems on that front. In the end I did things in the browser interface.
Just another user
Thanks for your help! I have the Apple iPhone app.
I will try the browser interface.
