I have 4 cameras 3 are getting great internet connection the 4th is in pole barn and can’t get good signal so I had a internet booster box installed in the pole barn but now I don’t know how to put the one camera on that box cause I only have one Arlo box that goes to the 4 cameras any advice on what to do
An wifi extender will not work for the cameras...they link to the base unit ONLY.
It sound like you have a couple of options...
1) use the internet extender ( with a ethernet port ) to centrally locate the base for all cameras
2) get a second base and use the wifi extender ( with port ) out in the barn for the close cameras
3) get a Q camera which links to your home wifi ( no base unit ) and will link to the extender
