For example... I exit front door, turn and lock door then leave via 2 steps and about 4 more feet that is seen on camera. Yet none if this is captured. Please suggest issue/resolution. Thanks much
unforunately this is part of the tradeoff you make for the advantage of battery operated. I also have a competing cam, same thing.
A trick I use which might work for you too.
I have a cam A set pointing to earlier in the motion I really want to capture, Cam B
and set a rule, when cam A detects motion to start recording cam A and cam B
gets posted regularly. read threads and you'll learn a lot.
On page 3 of the FAQ you'll see a video about modes.
Modify the armed rule, or better yet create your own mode and use it.
say cam A is the cam on your walkway and cam B watches your door.
create rule that when cam A detects motion start recording cam A
when cam B dtects motion start recording cam B
when cam A detects motion start recording cam B
oops. dont know where I got page 3 from. At the bottom of this and every forum page is a button Contact Support. click it. Under have you tried our knowledge base, click on go to support. Click on Arlo. The right video is Modes and Scheduling.
