Third Arlo camera keeps going off line
I just bought our Arlo Camera. The 2 camera works just fine but the third one keeps going off line. I have changed the location and the battery life but it still goes on and off line. What else should i do?
Open battery door and remove battery...
go to settings and use REMOVE DEVICE for this camera
install batteries
re-sync as if new
test again.
If it continues to go offline, contact Netgear Support ( or see if store will exchange )
Eod1hope,
Adding to the suggestions above, you might try swapping the location of the camera with one of the cameras that is behaving as expected. Does the issue follow the camera or the location in which the camera is placed?
