The original Arlo, all 5 cameras have started recording at same time, nothing active to set them off
  • 2 Replies
  • 2275 Views
RobOZ
All cameras have started recording at the same time.. There is nothing visible to cause them to record.. This happens multiple times a day. Two outside and 3 inside... I put one camera in a cabinet with no light and it too records. This has only been happening over the last 7 days. Was there a firmware update? Any Idea why this would happen.?
JessicaP
Hi @RobOZ,
What does the recording detection indicate as? Does it say "Motion" or "Audio" detected? Try to reboot your Base Station to see if that helps.
JessicaP
Hi @RobOZ,
RobOZ
Thank you for your response.  They all showed motion at the same time and recorded.   To fix I took batteries from cameras and refreshed but that didn't work. So i again took batteries out, and powered off both the Arlo router & the home wifi/router and let sit for 30 minutes and booted them up in sequence.  Once they came back up I put the batteries in the cameras.  One more reboot of the Arlo box and it seems to have taken care of the problem.  Thanks again.  Rob
