Hi @RobOZ,
What does the recording detection indicate as? Does it say "Motion" or "Audio" detected? Try to reboot your Base Station to see if that helps.
Hi @RobOZ,
Thank you for your response. They all showed motion at the same time and recorded. To fix I took batteries from cameras and refreshed but that didn't work. So i again took batteries out, and powered off both the Arlo router & the home wifi/router and let sit for 30 minutes and booted them up in sequence. Once they came back up I put the batteries in the cameras. One more reboot of the Arlo box and it seems to have taken care of the problem. Thanks again. Rob
