- 2
One camera out of four has started doing this since replacing the batteries.
This camera was the first to require batteries.
I changed the batteries (with OE) and am now experiencing 'The request timed out' message.
I have removed the batteries, refitted them, re paired the camera with the base station,reset the base station all to no avail.
However, very intermitantly, the camera works for a while.
Any ideas anyone?
I'm able to view my Arlo Q Plus remotely live with CVR on a mobile device, but when viewing on my PC the request to view live always results in a Request Timed Out. When I remove the camera from CVR service, I'm again able to view live feed from both my PC and mobile device.
I never see any answers here, just questions, but at least this a solution (a really bad solution) since I have to remove a feature I pay for (CVR) just to see a live feed.
Two days ago I purchased and installed an Alro Pro system with 4 cameras. All cameras are outside. With one of these cameras I receive the above stated error message. Interestingly, this camera is the closest to the base station and has the greatest signal strength; therefore, I believe signal strength is not the issue.
The main difference with this camera is its placement. It is near the power line for the house; however, I am not sure that is the issue either.
It is possible the issue could be related to the platform on which I view the cameras. It seems that I do not have the issue using the app on my mobile device whereas I have the issue viewing via a Safari browser ; however, with only having the system for 2 days, I cannot say that with certainty.
Regardless, I could care less if I receive an error message if I knew that I would receive notification if there were an intruder; however, to my knowledge Netgear personnel have yet to address whether that would happen or not.
Try swapping cameras around to see if it's the camera or the location.
Awesome suggestion!
I will change out the camera; however, it may take a week to complete as the location of the system is 400+ miles away from where I currently reside. As such, I think the system is great even with this small nuisance.
Separately, since my initial post I noticed that the time out occurs about the same time in the browser as it does in the mobile app (which I determine by observing simultaneously on two separate accounts, mine and one that I was granted access.)
- 2
