Text message notification is garbage
Text messages I get from Arlo are not very helpful. My carrier is AT&T. I get messages that look like this:
SUBJ:Arlo Has Just Detected Motion
MSG: This Just InaΔ¿ body{
(Con't 2 of 10
background:#EEEEEE; padding:45px 5%; margin:0; position:relative;
(Con't) 3 of 10
display:block; font-family:Arial, Tahoma, sans-serif; cursor:default;
(Con't) 4 of 10
line-height:normal; } a,img{ outline:none; border:none;
(Con' 5 of 10
} .fixed-table-layout{ display:table; table-layout:fixed; }
Mo
Not much you can do... att doesn't strip out the extra html crap.
But at least it notifies you and I always found the txt was easier to deal with than email.
Arlo could send plain text.
you could suggest it ...
As it is there is only Push or email at this time and the sms was a work-a-round.
Very odd.......
I have AT&T and my Text alerts look fine...... interesting
